Hi all
I have a strange problem with my cube orange.
My setup: cube orange with mRo u-Blox ZED-F9 connected via mRo KitCAN over CAN.
Issue: no GPS / satcount:0 (tested both CAN1 and CAN2)
Parameters for CAN:
CAN_P1_DRIVER 1
GPS_TYPE 9 UAVCAN
COMPASS_TYPEMASK->UAVCAN (Unchecked)
GPS_AUTO_CONFIG 2 (auto for CAN)
NTF_LED_TYPES UAVCAN
If I look in SLCAN with the UAVCAN Inspector I see that the ZED-F9 has a fix and gives data (see picture)
Still no luck.
I tried to reset to default parameter
I tried the M9N and M8N on UART GPS1 port but still no sats in status. (the GPS are working on a pixracer)
Telemetrie and Compass is working.
It is hard to imagine that this is a hardware problem?
Any suggestion from Cube orange users?
BRD_BOOT_DELAY,5000
to allow the CAN GPS to boot up and be ready when the Cube goes looking for it.
You might be able to reduce that delay to 3000 (3 seconds) but experiment once you have it working.
Many thanks for the responses.
I totally do not understand whats going on.
We switched laptops and everything was working!
I have to mention that I was connected by USB. Could the power on the USB have an impact?
