GPS ID can not found.
I also want to know the current GPS ID in the Mission Planner open-source project. When I search for MAV_COM_GPS in the mavlink.lua file, it shows GPS 1 as 220 and GPS 2 as 221. However, when I tested it, the component IDs appeared to be random. I only connected two components—one for ArduPilot and the other for GPS. Here are the results:
yaml
CopyEdit
Heartbeat received from Component ID: 1
Custom Mode: 1
Type: 16
Autopilot: 0
Base Mode: 0
System Status: 0
MAVLink Version: 1
Active Components: 2
Component IDs: 115, 1
Here is the code I tested:
csharp
CopyEdit
private string ProcessMavLinkMessage(byte[] buffer)
    try
        // Ensure that the MAVLink message format is correct
        if (buffer.Length < 10)  // Minimum length based on MAVLink protocol
            return "Error: Buffer too small to contain a valid MAVLink message.";
        // Extract common MAVLink headers from the buffer
        byte header = buffer[0];
        byte payloadlength = buffer[1];
        byte incompat_flags = buffer[2];
        byte compat_flags = buffer[3];
        byte seq = buffer[4];
        byte sysid = buffer[5];  // System ID
        byte compid = buffer[6];  // Component ID
        uint msgid = (uint)((buffer[9] << 16) + (buffer[8] << 8) + buffer[7]);  // Message ID
        // Display the basic info of the message
        string messageInfo = $"Message received: SysID: {sysid}, CompID: {compid}, MsgID: {msgid}";
        // Track unique component IDs
        componentIds.Add(compid);
        // Handle different message types based on msgid
        switch (msgid)
            case 0: // HEARTBEAT message ID
                return ProcessHeartbeatMessage(buffer, compid);
            case 115: // STATUSTEXT message ID
                return ProcessStatusTextMessage(buffer, compid);
            case 24: // GPS_RAW_INT message ID
                return ProcessGpsRawIntMessage(buffer, compid);
            case 232: // GPS_INPUT message ID
                return ProcessGpsInputMessage(buffer, compid);
            case 30: // ATTITUDE message ID
                return ProcessAttitudeMessage(buffer, compid);
            case 74: // VFR_HUD message ID
                return ProcessVfrHudMessage(buffer, compid);
            case 147: // BATTERY_STATUS message ID
                return ProcessBatteryStatusMessage(buffer, compid);
            default:
                // Return a generic message for unhandled message IDs
                return $"{messageInfo} (Unhandled message ID)";
    catch (Exception ex)
        return $"Error parsing MAVLink message: {ex.Message}";
