Zvir
(Zvir Celavra)
May 10, 2022, 10:30pm
1
My old GPS stopped working. I got a new one: GPS HGLRC M80PRO. The description said UBLOX protocol, but not sure why it came with NMEA…
The documentation says there is no problem - just change GPS_TYPE to 5… and possibly GPS_DRV_OPTIONS to 4 for 115.2Kbaud serial data rates…
Unfortunately, the GPS does not work.
Do you have any advice?
(I have checked the wiring etc)
cambull
(Stewart Campbell)
May 19, 2022, 8:09am
2
Have you checked your wiring that you have Tx-Rx, and Rx-Tx? That is a common mistake for UART connections. I assume since you had one previously working you know that, but I am asking just to be sure.
As for Ardupilot, someone more knowledgeable than I can answer that .
Zvir
(Zvir Celavra)
May 23, 2022, 12:54am
3
Of course I checked the connections.
In the comments on banggood it was mentioned that the manual said something different than the signatures on the pcb. I checked every possibility.
I also checked another BN-220 and it works normally.
I wrote directly to HGLRC… but they still ask about configuration with betaflight. I guess they are not aware of Arduplane existence.
So either something is wrong with this example, or arduplilot doesn’t work with this type of gps.
