Hi!!
I’m using a PX4…
I was first using the 3.1.3 stable release, loiter worked and was flying ok, but I had the 89 bytes logs problem…
Then I tried 3.1.4 beta, this one: firmware.diydrones.com/Copter/20 … /PX4-hexa/
And the logs started to work, I was able to check all the information, but then I tried loiter… and crashes occurred… I was able to save it, only some carbon tubes of the landing gear were broken… Then checking the logs, there is lots of GPS errors…
First flight 3.1.4 beta:
[attachment=4]gpserror1.png[/attachment]
Second flight 3.1.4 beta:
[attachment=3]gpserror2.png[/attachment]
Then I reflashed the PX4 to the latest release with APM planner 2, its the 3.1.4 I believed, and did a quick flight to test the logs, and now I back to the 89 bytes logs…
Failsafe GPS-0
Failsafe GPS-1
Failsafe GPS-2
Failsafe GPS-3
Err: GPS-1
Err: GPS-2
Err: GPS-3
And the position changed from one position to another… This used to work good with the stable version…
[attachment=2]89error.png[/attachment]
Log 1:
[attachment=1]14-05-21_17-21-28.bin[/attachment]
Log 2:
[attachment=0]14-05-22_17-39-24.bin[/attachment]
Log 89 bytes:
???YFMTBBnNZType,Length,Name,Format
Has anyone with the PX4 had this kind of problems??
So, if I use beta versions I’ll get logs but lots of GPS glitches, if I use stable versions I have GPS but no logs… Does anyone think my board is faulty??
Any ideas?? recommendations??
Cheers!!
