my hexacopter today crashed because of GPS glitch (I think). After 1:30 min in LOITER the plane started to move very quickly forth and back and then it exceeds 60 deg. pitch angle and just fall. Can I change some parameter to avoid such as situation ? PID’s are from AutoTune which I did just yesterday.
Thanks
Martin
No of lines 5374
Duration 0:01:45
Vehicletype ArduCopter
Firmware Version V3.2.1
Firmware Hash
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
Test: Compass = GOOD - No MAG data, unable to test mag_field interference
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: GPS_GLITCH
Test: GPS = FAIL - GPS glitch errors found (1)
Min satellites: 0, Max HDop: 99.99
Test: IMU Mismatch = NA -
Test: Parameters = GOOD -
Test: PM = FAIL - 3 slow loop lines found, max 14.70% on line 4328
Test: Pitch/Roll = FAIL - Pitch (78.74, line 5173) > maximum lean angle (45.00)
Test: Thrust = GOOD -
Test: VCC = FAIL - VCC below minimum of 4.6v (4.578v)
