Hi
I have a 450 Quad fitted with a APM board. On looking at the log from my last training flight, I noticed that it is showing a lot of Err GPS-2 and GPS-0 errors. Looking at the number of Sats, it shows between 6 and 7 for most of the flight duration.
Can anybody explain what would cause this please? Log files attached
Hi
I did say please.
My Analysis program finds many issue here.
Did you wait 5 minutes for the GPS to stabilize before arming?
I ask because you have many GPS issues as you take off…
16/05/2014 17:48:00 - 000328: Take Off
16/05/2014 17:48:00 - 000328: Mode Time Changed to 16/05/2014 17:48:00
16/05/2014 17:48:00 - 000329: GPS ERROR: GPS Glitch.
16/05/2014 17:48:00 - 000342: NOT_LANDED
16/05/2014 17:48:00 - 000344: GPS ERROR: GPS Glitch Cleared.
16/05/2014 17:48:08 - 000442: GPS ERROR: GPS Glitch.
16/05/2014 17:48:08 - 000446: GCS Heartbeat Error: GCS Heartbeat signal has been lost!
16/05/2014 17:48:08 - 000446: GCS Heartbeat Error: Current Distance from Launch is 0.55m ~ 1.82ft
16/05/2014 17:48:08 - 000446: GCS Heartbeat Error: Current Direction of UAV is 152 degrees (0 = north).
16/05/2014 17:48:08 - 000446: INAV Error: A navigation error has been detected.
16/05/2014 17:48:08 - 000446: INAV Error: Current Value of PM Parameter PM_INAVErr is 255
16/05/2014 17:48:08 - 000446: INAV Error: An update will be displayed if the value changes.
16/05/2014 17:48:08 - 000505: GPS ERROR: GPS Glitch Cleared.
16/05/2014 17:48:16 - 000973: GPS ERROR: GPS Glitch.
16/05/2014 17:48:16 - 000983: GPS ERROR: GPS Glitch Cleared.
16/05/2014 17:48:23 - 001495: GPS ERROR: GPS Glitch.
16/05/2014 17:48:23 - 001526: GPS ERROR: GPS Glitch Cleared.
The program points out that the arming check is not set to do a full check, did you mean to do this?
ARMING_CHECK = -9
Warning: Pre-Arming Check is not Active (0=Off & 1=On)
Also not that you RTL is set less than 15m
PARAMETER ISSUES:-
RTL_ALT = 1000
Warning: Return to Launch Altitude is less than 15 meters (Value in CM)
Your APM is also struggling at times:-
16/05/2014 17:49:19 - 005768: APM Speed Error: The number of long running main loops is 2 @ 96.227ms
16/05/2014 17:49:19 - 005768: APM Speed Error: A one off here could be ignored but if repeated in this log,
16/05/2014 17:49:19 - 005768: APM Speed Error: then try disabling some logs, for example INAV, MOTORS and IMU
Personally, if you did not wait 5 minutes before you flight then do this first and try again.
If it is the same then first you need to sort your GPS issues!
The program can be found at:-
http://www.rcgroups.com/forums/showthread.php?t=2151318
Cheers
Kev
In fact, looking at that Arming Check value it is “not valid”.
In view of this I would do a reset and erase, then do all the setup again!
Do you upgrade the firmware without do this?
Cheers
Kev
Hi
Thank you for the reply, I’ve not been on the Forum due to decorating for the last few days…
I disabled the GPS on boot up, (surrounded by other houses), as I am only hovering in my garden. On the log it shows At least 6 Sats during the flight, yet it is still coming up with errors, or is that to be expected due to glitches?
