After updating to 4.6.0-beta1 I had the problem today (Tritilt VTOL, BZGNSS BZ-251 GPS / u-blox M10 chip, Mateksys H743 white), that could not be armed due to problems with the GPS configuration:
Messages: GPS 1: probing for u-blox at 230400 baud u-blox 1 HW: 000A0000 SW: ROM SPG 5.10 (7b202e) Arm: GPS 1 still configuring this GPS GPS 1: u-blox solution rate configuration 0x80008
GPS has perfect reception, status 4, 14-16 sats, HDOP < 0.85
Here is the short prearm log file: MagentaCLOUD
At home, I switched back to 4.5.7. stable, which did not have the problem.
To cross-check, I reinstalled 4.6.0-beta1, and the problem was back. To be able to fly with the VTOL and 4.6.0-beta1 for the time being, I disabled GPS_AUTO_CONFIG so that it can be armed.
On 2 other airplanes with different GPS (M8N) the problem did not occur when switching to the beta.
The Beitian BE-220 on my Drift did not have any issues with 4.6.0-beta1.
EDIT:
Confirmed, with the BZ-251 it keeps trying to write configuration and at some point the ESC starts to beep. Something seems to hang-up here. But it took a couple of reboots to reach this scenario.
You may have to enable auto config once. From what I have observed, it does set “Airborne >4G” and the baudrate but leaves SATS / GNSS options untouched.
The annoying part is that it takes a couple of attempts because some conditional evaluation is not correct in AP4.6. I’ve seen a patch commit somewhere recently.
