I am working on a drone platform running ardupilot 4.5 with a gremsy S1V3 mounted to the underside. The gimbal payload includes a camera and a laser source. I am trying to achieve accurate pointing (1 degree) of the laser over a distance of 100m.
We also have an RTK base station set up that is surveyed down to an accuracy of 0.5m.
In mission planner when i run the ‘point camera here’ or the ‘point camera coordinates’ there seems to be a constant 5 degree offset in the gimbal pointing.
I have surveyed the target coordinates using the drone itself to avoid any geolocation errors from the mission planner gui.
It would be great if there was a mnt_yaw_offset parameter in ardupilot 4.5 but i can’t seem to find it.
Has anyone had similar issues in precision camera pointing and managed to find a repeatable solution?
