“Getting Params 1” ? Forever in MP
I am able to cnnect my DJI Matrices 100 Quadcopter to Mission planner (version 1.3.586) through UDP connection.
But after I connected to Mission Planner, there is a pop-up windows shows that “Getting Params 1” mode. The pop-up windows is always shows up without any progress forever. Looks Like it cannot be able to retrieve the parameters.
Only option I have is to cancel this process or let it run hours on end. After cancel the “Getting Params” pop-up windows, there is another pop-up windows say “Home position is not updated”.
What are parameter needs to send from Quadcopter to Mission planner ?
Can anyone help me to what are minimum paremeters are expecting by Mission planner? is there any example available for sending these parameters from Quadcopter to Mission planner ?
Appreciated your support!
Thanks
Regards
Jo
Hello, I am having the exact same issue. I know this thread is kind of dead, but if you @jothi or anyone else managed to resolve this, an answer would be much appreciated. Thank you.
If you’re using DJI hardware, Mission Planner will be of little use. DJI uses a closed source protocol. There is a project called RosettaDrone that supposedly allows MavLink control, but I don’t know how effective it is.
