I have two servos, one controlling the left aileron and one controlling the right. I want to get the PWM value for each one, but I can only seem to acquire one of them using the following:
local aileron_pwm = SRV_Channels:get_output_pwm(4)
No way to do this unfortunately, you can only get the PWM of the first function. The scaled output is the same of course, so you can manipulate it and then output to a scripting servo function. If you can explain what your trying to do we may be able to suggest a alternate approach.
Got it, thanks. That is essentially what I am currently doing.
The purpose is to reassign a bicopter’s tilt wings as ailerons after transitioning from VTOL to FW flight. Appears to be working on the ground as anticipated. I am having massive problems taking off in auto mode though (unrelated to scripting ), as discussed at Bicopter Takeoff Issues - ArduPlane / VTOL Plane - ArduPilot Discourse.
Hey! did you manage to do that ? I am not able to access pwm output values with lua. I tried SRV_Channel::k_nr_aux_servo_functions-1 and SRV_Channels:get_output_pwm() without a success
