Get latitude and longitude
Hello, my name is Johann, I have a question, ¿How can I in Mavproxy get the latitude and longitude of a quadcopter?
Thank you very much.
There’s not currently any command to do that. You’d have to write a custom module.
Something similar to the antenna pointing module would work: https://github.com/ArduPilot/MAVProxy/blob/master/MAVProxy/modules/mavproxy_antenna.py
Otherwise, you could just click on the UAV on the map view and get the longitude/latitude, if you’re just looking for a quick solution.
I do not know … go to dyi-drone of arduo-copter forums and they can help
you! Good luck!
Type
Alt on the cmd line after the mavproxy is up and running.
I am so sorry, I don’t know. I was looking for an older version of Mission Planner. My APM 2.5 is not working with the latset version. I am only flying with gliders
Gr. Han.
Hello, here the solution in mavproxy, I add the next code:
master=mpstate.master()
lat = master.field(‘GLOBAL_POSITION_INT’, ‘lat’, 0) * 1.0e-7
lng = master.field(‘GLOBAL_POSITION_INT’, ‘lon’, 0) * 1.0e-7
Thank you.
