Unlukily I can not install Mission Planner. I downloaded the latest version but no matter what I try I always get the error message while installation “Installation directory must be on a local hard drive” I selected my local hard drive C:/ where all my programms are installed to. Also no other directory worked. Anybody knows the problem? Thanks for your help and sorry for my bad English…
You need to run the installation as an administrator.
Find the Command prompt in the Start menu -> right click -> Start as an Administrator ->
change directory to the one with the Mission Planner .msi and execute the installer. Now it should run OK.
