I’m trying to use the time array using the logs generated by PIX Hawk 4.3.3 (converted to .mat format) to compare with an external information. I import the log files with the Scipy library in Python, the data contained in the file is imported as a dictionary variable, so that I can access the information contained in this dictionary. I need to compare the information contained in the log with another log that is referenced by time (YYYY-MM-DD HH:MM:SS format), so I need to synchronize the information of both logs using time. However, the time information contained in the log generated by PIX Hawk is based on a timestamp relayed to something datetime, so I need to convert that timestamp information to YYYY-MM-DD HH:MM:SS format, the problem I I don’t know where what is the time that is used as a reference to generate the timestamp or where I can find more data that helps to do this conversion.
