Geotag error after Cube Orange Plus with 4.3.6
After start to use CubeOrange Plus with the fw 4.3.6 i´m having a insue with trigger vs cam message during geotag process. Initially i thought the problem was with the shutter board (that transforms pwm to relay) to trigger the camera(Sony a6000) i did several tests changing the time of the duration shutter to prevent trigger more than 1 picture at same time, did not work, so i change the shutter from servo to relay, and the same error occurred. I was also using a pullup resistor in the hot shoe, so i removed it to, even so i still having problem with the “cam” message(return of hotshoe). With the “trigg” message the geotag works very well but i if the camera freeze, or turn off during the flight i won’t be able to know.
I had problem with duplicate, sometimes triplicate the cam message
Are different drones, with different cameras, but the same hardware: CubeOrange Plus with 4.3.6
I uploaded 2 different drone logs
https://drive.google.com/open?id=13j70i76up6wFR3MsdMYepVRNo23nvhmX&usp=drive_fs
Is your problem solved??
Hi @And123 I think I solved it, but it was a problem related to interference from the new Cube Orange + board. I´m trying to use a capacitor in servo rail, and change pwm servo voltage to 5.
