Is there a difference between sending a MAVLink command vs setting value 1 in the FENCE_ENABLE parameter?
Should be no difference
Thanks @amilcarlucas, it seems that sending this command does not set the FENCE_ENABLE parameter, however it seems working - restrict drone from flying beyond fence, and triggers fail safe for enabling the fence if drone is outside (breach).
How can I tell the current fence state without the parameter ?
