Perhaps you could integrate a “return to home” function in ardupilot (if not already the case) and a “pitstop” function. Both would require the ability of the flight controller to operate the gear (first one just for landing on the gear, second one to land on the gear and take off from the gear with a user-settable wait time in between). The wait time should be settable depending on the time it takes to recharge the plane.
Also, are you actually working on an electric recharge station for RC planes (and other ardu-vehicles ? If not, perhaps worth considering. There seems to be one project involved in this (see https://phys.org/news/2016-10-drones-re-charge-airborne-technology.html ) but really, it doesn’t need to be wireless. An electric conducting pole or something could also be used. The plane can then just taxi to the pole and extend a metal beam to touch the pole and send the power to it’s battery.
There is already a return to home function in ardupilot, it’s called RTL (return to land)
There are already pitsop function, those are called “rally points”
There is no comunity developped hardware for recharging yet. And no software for that.
See here
It says it will “loiter”, so won’t land.
Same with rally points. Only copters will land, not planes.
Also, the pixhawk for instance doesn’t have a channel for the gear either, so ardupilot can’t extract or retract the gear.
Taxiing too can’t be done (can’t be commanded via the route planner, and the recharge function in which to taxi to it for the last 10m or so doesn’t exist).
