setting this to ‘1’ = ‘On’ does the following regardless of the order in which things are started. After 20 seconds of both radios w/ solid green lights on [ stock time for a long event ] it goes into failsafe. This even while APM P is connected fine. With both radio’s and Pixhawk [ or amp 2.x it does it with both ] still on … I toggling back to manual… then remove gcs radio and wait. Now it doesn’t go into failsafe.
So to summarize it goes into failsafe on start up no matter what. Then will not go into gcs failsafe again unless you reboot the controller. So it seems APM P isn’t telling the controller the connection is good??
I tested this several times with the exact same results. I also tested it with a PC and MP [ old version 1.2.53 I think ] and it does not seem to have the same problem. It does not set a failsafe after start up only after gcs radio is off for 20 seconds. Just as it should.
Check that AP2 link to the radio is sending mavlink hearbeat meassages. This is in the advanced part of the serial cconfig dialog. It should be enabled by default.
OK yes I see that now. However it still goes into failsafe even while connected. If it’s working for you then perhaps it’s something with APM Plane 3.0.3 ? Are you testing it with that or APM copter?
