hi all
I’m working on a ubuntu 21.10 impish
I ve installed gazebo 9 as required in Using Gazebo Simulator with SITL — Dev documentation
but when asking for version it says 11
$ gazebo --version
Gazebo multi-robot simulator, version 11.1.0
Copyright (C) 2012 Open Source Robotics Foundation.
Released under the Apache 2 License.
http://gazebosim.org
when trying to launch irisworld I get error about sdf 1.7 not compatible and I dont know how to change this
gazebo --verbose worlds/iris_arducopter_runway.world
[Msg] Waiting for master.
[Msg] Connected to gazebo master @ http://127.0.0.1:11345
[Msg] Publicized address: 192.168.1.104
[Msg] Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
Error [parser.cc:525] parse as sdf version 1.7 failed, should try to parse as old deprecated format
Error Code 4 Msg: Required attribute[xmlns:xacro] in element[sdf] is not specified in SDF.
Error Code 8 Msg: Unable to parse sdf element[sdf]
[Err] [World.cc:193] Error Code 23 Msg: FrameAttachedToGraph error, Non-LINK vertex with name [__model__] is disconnected; it should have 1 outgoing edge in MODEL attached_to graph.
[Err] [World.cc:193] Error Code 23 Msg: Graph with __model__ scope has sink vertex named [__model__] when starting from vertex with name [__model__], which is not permitted.
[Wrn] [Publisher.cc:136] Queue limit reached for topic /gazebo/default/physics/contacts, deleting message. This warning is printed only once.
[Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
[Wrn] [Publisher.cc:136] Queue limit reached for topic /gazebo/default/user_camera/pose, deleting message. This warning is printed only once.
I didn’t find any one here who get same error
