Fuel Flow Sensor with cube black
I have a Jeti MFlow2 Fuel Flow Sensor that i am trying to integrate with cube black in the documentation i found this
https://ardupilot.org/plane/docs/common-fuel-sensors.html?highlight=fuel%20flow
the MFlow2 looks very similar to the biotech one but it comes with a attached circuit board ( not sure what it does) and a three pin output. Has anybody got this to work before or any helpful ques how i should go about doing this.
I powered up the ground and 5 volts through AUX 6 (GPIO) and looked at the voltage between signal wire and the ground … it was oscillating between 2.15 to 2.8 volts just sitting on the bench. blowing through the flow meter didn’t make any difference to the reading on the volt meter at all.
Hi Tim!
I am Ivan and I’m looking to use a liquid flow meter similar to the Jeti MFlow2 Fuel Flow Sensor for fuel volume monitoring on our team’s quadplane.
The one I am considering is this one by Bio-tech.
May I know if you have already started using your Jeti flow sensor? If so I would like to find out more about its performance.
