Frsky Variometer HP at Mateksys F405
I´m using:
  • Frsky Taranis QX7 ACCESS (OpenTX 2.3.10, ISRM-N 1.1.1/2.1.0EU)
  • Frsky ARCHER RS (1.2.0/2.1.2)
  • Matek 405-Wing (arduplane_with_bl latest about 20.12.2020)
  • Beitian BN-220 GPS
I want to use:
  • Frsky Variosensor HP
How can I connect the Frsky Variosensor HP to the F405?
The sensor has two ways to send the data:
  1. with SmartPort
  2. with the older Data output from Frsky.
Do you have any ideas?
I try to use RX1 with different parameters, but it doesn´t work.
Thanks
Michael
I don’t think ardupilot supports that verio specifically. What you could do is assuming the rx has a s port is hook the verio s port to rx sport and you will get the vertical speed and altitude back to the tx. I think but I don’t know just a guess, once you have the verio and rx connected through s port then you can try to hook it to fc. How do you have your rx connected to the fc? Fport? Sbus?
