Ah! I did read a bit about that bug but did not fully digest its impact (it seemed Betaflight specific). That makes perfect sense, and the developers here can disregard my somewhat ignorant request for support. Thank you much for the explanation!
A brief test with the ACCST 2.1.2-beta firmware linked in that bug report was completely successful. A word of caution to those considering this “fix” - there is a follow on post that appears to blame a copter crash on this beta receiver firmware, so it probably shouldn’t be used in any critical application. In my case, I’m using it on a small Rover that I purpose built to test things like this, so the risk is close to nil.
In the long run, perhaps it might be best to simply upgrade my transmitter with an ISRM module and transition to ACCESS.
Read this and some other posts in order to make the telemetry work for my setup. I´m using the latest firware versions on my setup.
Cube Orange - Arducopter 4.1
Taranis X9D Plus SE 2019 - ISRM-S-X9 1.1.0/2.1.6FCC
Receiver: Archer RS - Archer -x 1.2.0/2.1.8
I´m making tests with 2 receivers, one with a 10k resistor on TX/GND and one without. I´m not using any adapter board. I tried Serial 1, 2, 3 and 4. RC signal OK with all of them but I never get Telemetry for my Yaapu script. I also tried F,Port and FBUS(FPORT2) Archer receiver protocols. The only thing I did not try was a solution with a Diode.
What can I be missing? Anyone with a similar hardware? Thanks.
What’s your related serial parameters?
Are you wanting to use F-Port or S-Port?
For S-Port you need a serial port set to something like this:
SERIAL2_BAUD,57
SERIAL2_OPTIONS,7
SERIAL2_PROTOCOL,10
the option listed here should be correct your Cube but you could need a pull-down resistor.
There’s some really good F-Port info right in the first post of this thread, and for the Cube Orange too.
@xfacta I have tried your setup (did not work) but I need to use Protocol 23 (RCIN) since I´m using Fport (SBus is in he same wire). I´m having no trouble with SBus, only telemetry.
@havran I will try your suggestion on monday (I don´t have the resistor with me but I´m already using your parameters). Do you have the same Radio and receiver (Taranis X9D Plus SE 2019, Archer RS)? I´m asking since there are several reports about telemetry problems related to Taranis fiirmware versions but on other FrSky TX/RX hardware, not the one I´m using. In fact I have not read about someone using the Archer RS receiver in the posts…
What are your RC_OPTIONS? 8 or 0?
Does SERIAL?_BAUD have any influence? I also tried 57,115
I successfully use the following settings (as recommended) on Cube Orange(s) with current ACCESS FPort firmware on an RXSR and also an Archer RS. I use a 10k pulldown resistor on both. I also had success with beta ACCST firmware on the RXSR, linked below.
If you have good RC control and a 10k resistor between signal and ground, then the wiring is not the problem. I suspect a transmitter issue at this point. Unfortunately, I do not use a Taranis transmitter, so I’m not much help there.
I have the Radiomaster TX16S, R9MX receiver (ACCESS) and Cube Orange. RC_OPTIONS = 0.
I tried all combinations and nothing worked. After replacing the resistor from 10k to 4k7, the telemetry started working.
