I dont think it is possible to interface S.Port sensors to ardupilot. Stick to the documentation about which sensors can be used
FrSky FPort support - testers wanted
yes, that makes the FC behave like a sensor on the Rc-Recivers s.port bus
Hi, this is not supported ATM, ardupilot cannot be a master on the SPort bus, a receiver is always needed. FRSky sensor can be chained on the sport bus along ardupilot but ardupilot cannot use them, like @Simon_Exner said ArduPilot acts as a slave.
Thanks for confirming!
As I am using an r9m which has the same pin for f port and s port , does this now mean I cant chain the sensors as I am using F port ?
So I need to go back to the old way of Sbus and s port ?
Yes, fport does not support chaining. Fport2 does
Yes I am on Fport 1 and ACCST.
Thanks for the help.
Sorry, created a new post, should’ve put it here…
I am in the middle of a new build and was trying to give F>Port a go. So, I have r-xsr flashed with fport accst firmware, updated my Taranis with latest OpenTX, flashed internal module, hooked it all up according to instructions:
BRD_ALT_CONFIG=1
SERIAL7_PROTOCOL=23
SERIAL7_OPTIONS=15
RC_OPTIONS=8 (did not work at all without it)
RSSI_TYPE=3
The thing is, I can’t get telemetry consistent. I can discover GPS sensor for a sec, as well as YAAPU script responds for a sec, then nothing. If I hold bind button on RX, it switches to whatever other mode and I lose control (no movement reported on TX calibration page) but telemetry goes for a second again and stops. I hold bind button again, blue light comes on on rx, I regain control, telemetry turns on again but again only for a second or so.
Using Arduplane 4.1 dev (latest)
So, I have reverted back to SBUS and smart port telemetry, and it works fine.
Is FPort broken or am I missing something here?
I have Fport working on a Matek H743 with the same configuration you have except for RC_OPTIONS (not needed). It’s an R9mm-OTA with ACCST Fport but that shouldn’t make any difference. Another with a Kakute F7 Mini with similar config. So, not broken. Using Arducopter 4.1.0-dev.
Hello Tridge,
I heard F405wing can be Fport without inverter if there is invert signal output from the receiver. it is true? how can i set it up? my receiver are R9MM and R9slim+
You will have to use “inverted S port” pad of R9MM to make FPort work with F4 boards without inverter.
I followed the Fport setup. but it did not work. I just could not figure out what did I miss. neither F765wing and F405wing. is it possible to have video tutorial to look at? or something that i can refer to one step by another? thank you for your help
@Anton_Khrapov
I had a similar situation where i spent full 2 weekend days and ended up finding a simple issue. It was RSSI. Yaapu script will not work if there is no RSSI in the mavlink stream(assuming you are using Mav2PT converter).
Just to try, setup RSSI as 1 (analog) even if you don’t have anything connected to analog pin. Just a test and see if you get Yaapu script working.
Try
SERIAL1_PROTOCOL = 23
SERIAL1_OPTIONS=7
Also make sure your R9mm receiver is flashed with FPORT firmware.
The most important step
Which FC you mean?
For the F405wing here is what I did
F4 based autopilots using an “inverted FPort” output from the receiver can connect it to any UART’s TX pin with the configuration:
SERIAL7_PROTOCOL =23
SERIAL7_OPTIONS = 4 (Half Duplex)
RSSI_TYPE =3
RC_OPTIONS = 8 (either =0 tried both)
BRD_ALT_CONFIG =1
Uart1 TX to the r9mm receiver
For the F765wing
BRD_ALT_CONFIG =1
SERIAL7_OPTIONS =15
RC_OPTIONS =8 (either =0 tried both)
RSSI_TYPE =3
Uart6 TX to the r9slim+ receiver
neither of the FC works for me. I don;'t know what I miss.
I meant F405 board.One more thing.You must run the latest version of Arduplane.Not sure if Fport has made to the stable yet.
I used SERIALxx_OPTIONS=7 on my omnibus F4 board thou.
Try serialxx options=7, protocol=23, rssi_type=3
and make sure that no other uart has serialiN_protocol=23 or 10
Also make sure you connect signal wire from r9mm to the TX pin of your FC. Serial options 7 is to swap Tx with Rx I think.
Make sure that no other serial is set to S.Port or something alike.
