FrSky FLVSS LiPo Voltage Sensor with SMARTPort
I’m hooking one of these up, but not sure I have it installed correctly. I connected the signal pin on the voltage sensor’s smart port to the signal pin on the receiver’s smart port, the + pin on the voltage sensor’s smart port to the + pin on the receiver’s smart port pin, and the middle pin (-) to the middle pin on the receiver’s smart port -.
I didn’t even think about it, but then I decided to see what the instructions show to do, and they appear to be showing the opposite. Is that right? I should connect the signal pin on the sensor to the - pin on the receiver and vice versa? In other words, reverse the cable end?
See photo of how I thought to hook it up vs. instructions wiring colors:
