I have the F765-WSE. I chose F765-SE when upgrading, as is recommended by Matek.
Watts, amps, and airspeed are stuck at some value that seems to be from initial launch (666watts). The battery voltage may be stuck too. It never decremented. I checked that the settings are correct, against the settings recommended by matek. (They were working and correct when using 4.1.0)
What could cause this? This was the first flight after upgrading from 4.1.0 to 4.2.3.
I flew another flight today. The DJI OSD stats are correct initially. Then, right after launch the following stats are stuck/frozen at what seems to be their reading during lunch:
Amps
Voltage
Watts
Air speed
Also, the distance to home metric keeps bouncing between 5,000 ft and 6mi
The other stats seem to be fine, like direction to home, GPS coordinates, altitude ascent, descent rate.
Also, the mavlink stats being sent back to q ground control on my phone seem to also be correct.
@tridge@yaapu Do any of the developers check these posts? Seems like it wouldn’t be much trouble to check and see what posts are new for about 10 minutes a day.
I just tested this in SITL (the simulator) using Copter 4.2.3 and it is working as expected,
That must mean that the simulator isn’t able to simulate the problem, or the right conditions were not met in the simulator to reproduce it.
Either way, the problem exists. Myself and the other developer experienced it.
Remember what was mentioned earlier, the metrics seemed fine until takeoff, at which time that specific metrics mentioned in the previous post get stuck at the takeoff values.
I need to investigate further on this issue, as I am just starting into DJI OSD stuff
Here are my parameters:
ArduPlane 4.2.3
SERIAL2_BAUD |115
SERIAL2_OPTIONS 0
SERIAL2_PROTOCOL 33
Flight Controller is a PIXRACER
Both the Goggles and Air Unit (RUNCAM)are running …0606
I will try @yaapu configuration above and report back.
I’ve done a full lfight, stats are updated in flight, at least in SITL, can you do a video please, of the main OSD screen and the stats screen? No takeoff required, simply arm and let the motor spin to accumulate some mAh
