Is the follow me mode supposed to control the camera (copter yaw and gimbal tilt) when I use follow me mode? If it should, do I need to set any special parameters?
Currently it can follow me and go around me, but it doesn’t actually aim the camera towards me.
Thanks for your answer.
I just went out and tested again to verify that it doesn’t work for me, now that I know it should. And what do you know; it worked.
I have been messing a little with my settings, and thinking that it might be my mnt_mode which have been messed up.
Now it’s set to 4 (gps-point) and it worked. I don’t know if that’s what made it work, but I just wanted to point that out as a possible solution if anybody else come across this problem.
