does anyone know how to setup apm planner or mission planner for a follow function.
ie. you give a motocross athlete a gps chip to put in his pocket and lock the multi rotor onto the chip’s coordinates in 3d space. Allowing the multi rotor to always maintain the same approximate position relative to that of the motocross rider.
APM Planner 2.0 does not support follow-me. Tower and DroidPlanner (using smart watch like pebble or Android Wear) does.
some 411 I just came across on the topic at ardupilot.com
Follow Me Mode
Follow Me mode makes it possible for you to have your copter follow you as you move, using a telemetry radio and a ground station. Mission Planner for Windows laptops, APM Planner for OS X laptops, and DroidPlanner for Android devices currently support Follow Me; however, it’s easiest to use a phone or tablet as your Follow Me ground station.
Follow Me mode uses the Copter dynamic waypoint feature and MAVLink telemetry commands.
Contents [hide]
1 What you’ll need
2 Instructions for Mission Planner
What you’ll need
An Copter with telemetry
A laptop
A GPS USB dongle like this or Bluetooth GPS module like this.
Set one of your flight modes to “Loiter”
Set up your Copter at the field and establish a MAVLink connection over wireless telemetry
Ensure that your GPS USB dongle or Bluetooth device is plugged into to your laptop and showing up as a serial port. Using the software that came with the module, make sure that it’s working and that you have GPS lock.
Take off, and once in the air switch to Loiter. (Sufficient altitude to ensure that while it is following you it isn’t attacking you might be a good idea).
In the Mission Planner Flight Data screen try right-clicking on a nearby spot and select “Fly to Here”. If this works, you’re ready to try Follow Me mode.
In the Mission Planner, enter Control-F, which will open the following window. Click on “Follow Me”
This will bring up this window. Select the serial port that is assigned to your GPS device and whatever baud rate it uses.
Once you click “Connect”, the Mission Planner will read the GPS data from your device and send it to your Copter as “fly to here” commands every two seconds.
Now pick up your laptop and start walking around.
The Copter should follow you!
If you have set the altitude to 5 feet it might be a good idea to see if you can out run it.
As mentioned before, sufficient altitude to prevent injury is useful.
Seriously this is a great capability, but safety is really important when using Follow Me mode especially with an open bladed Multicopter.
Warning: Like all other modes in which the autopilot is responsible for altitude hold (Loiter, AltHold), the barometer is used in the altitude calculation meaning that it can drift over time and the copter will follow the air pressure change rather than actual altitude above ground.
Questions about this page? Comments? Suggestions? Post to APM Forum! Use the platform specific to your query, and make sure to include the name of the page you are referring to.
It’s a mistake to say APM Planner 2.0 supports follow-me, it doesn’t
It appears that you are correct. Must have been a misprint on the ardupilot site.
copter.ardupilot.com/wiki/flying … _followme/
I believe Q ground control has follow functionality on the mac. I have had a brief overview of the application. It seems to be really advanced looking but lacking the ease of use and stability of apm planner or mission planner. Anyone had good experiences with Q ground control or Auto Q Ground control?
