just want to get a clarification of it.
when powering thru USB, FMU B/E LED is off.
when powering thru battery-PM, the LED is slightly on (on but DIM)
I wonder what might the problem be and what does it mean. if it is safe to fly as is
This is normalwhen powering thru battery-PM, the LED is slightly on (on but DIM)
This is normal. You are actually seeing the power LED bleeding over to the B/E LED
I get the same. When you say [quote] power LED bleeding over to the B/E LED [/quote] do you the green light or the voltage?
Yours Simon M.
I’m having the same issue, I don’t think it is the power light bleeding over as I would think that it would dimly light the B/E green. My B/E is lit amber but only when I use a battery to power the system.
the light
I’m with this light this is normal? and safe to flight with this ? only when battery plugged.
Check attached file…
Thank you for help.
[attachment=0]rps20140720_093557_172.jpg[/attachment]
I also got this problem
How can I do
I have asked 3DR support. According to them, this behavior is normal and does not signal an error.
So this is a bug or feature on their side.
