Maybe I dreamed this, but I could have sworn there was a way to drive make this AIO board output PWM (to drive servos) through one of the ESC pads for each motor? I’m sure I would need to manipulate the hwdef.dat file I’m just having issues finding any evidence of how.
The GOKU GN 745 AIO supports up to 8 PWM outputs. The pads for motor output ESC1 to ESC4 on the above diagram are the first 4 outputs, there are four additional pads for PWM 5-8. All 8 outputs support DShot as well as all PWM types.
The PWM are in 5 groups:
PWM 6: Group 1 PWM 1-2 and 7-8: Group 2 LED: Group 3 PWM: Group 4 PWM 3-4: Group 5
Channels within the same group need to use the same output rate. If any channel in a group uses DShot then all channels in the group need to use DShot. PWM 1-4 support bidirectional dshot.
PB0 TIM3_CH3 TIM3 PWM(1) GPIO(50) BIDIR # Motor 1
PB1 TIM3_CH4 TIM3 PWM(2) GPIO(51) # Motor 2
PE9 TIM1_CH1 TIM1 PWM(3) GPIO(52) # Motor 3
PE11 TIM1_CH2 TIM1 PWM(4) GPIO(53) BIDIR # Motor 4
PC9 TIM8_CH4 TIM8 PWM(5) GPIO(54) # Motor 5
PA3 TIM5_CH4 TIM5 PWM(6) GPIO(55) # Motor 6
PB4 TIM3_CH1 TIM3 PWM(7) GPIO(56) # Motor 7
PB5 TIM3_CH2 TIM3 PWM(8) GPIO(57) # Motor 8
Ok, but note that this is an All In One board. The ESCs are hardwired to those pins. I believe setting those motors to PWM will send PWM to the input of the ESC not to the output pad
