Flying with Rudder, Elevator, Throttle (no ailerons)
I set up a small plane with rudder, elevator and throttle controls only - no ailerons. I put the rudder servo on the aileron channel.
The plane flies well and the flight controller works fine in AUTO mode.
I just noticed that there is a parameter for rudder only operation: RUDDER_ONLY mode.
What is the advantage of using the rudder only set up in ArduPlane?
Thanks,
Paul
