I’m new to Ardupilot and I’m trying to configure my plane for its first flight. However, I can’t seem to find the FLTMODE_CH parameter in either the standard/advanced params lists. It does show up in the full parameter list and the full parameter tree, both showing that the flight mode is assigned to ch 8 (I need it assigned to either ch 5 or 6). From what I can tell, it should be a simple matter to reassign the channel, but I haven’t found others who have encountered this issue. Is it a firmware problem? Should I reinstall Mission Planner? Any help is appreciated.
Thanks!
Casey
