Could you tell me what should I do?
As of now I realise my Mac does not support the latest APM planner 2 and have called for a windows laptop.
You think that could sort the flips?
I’ll download the latest mission planner (for windows and update the firmware and follow all the process to get the drone calibration done, do you have any link to a youtube video which could help me with the process?
I changed the frame also thinkkng it could be a issue with the balance.
I use the APM 2.8. I do not have a gps and compass. This was just a basic build. I plan to sort the basic build first and then upgrade to the add ons like gps, fpv camera, telematry and a GoPro
Forget what I said. That Flight Controller hasn’t been supported in Ardupilot for years, it’s obsolete. You should be posting in the Copter 3.2 thread (moved it for you).
Get a new Fligt Controller that’s supported by current Ardupilot. There are many.
I know that. 5 years ago I had several APM 2.6’s and 2.8’s. Just to update you the last Arducopter firmware to run on those boards is 3.2.1. Today we are at 4.0.7
Have you checked servo output tab on setup. Did you recognize any uneven output on the servos even the quad is on its nees and propellers not attached. Applying throttle above %50 makes servo outputs different on each motor? This means there is a bug with arducopter 3.x and above with apm 2.8. Since I have the same issue out there. I will use previous versions for example arducopter 2.6. Then will update here.
