Flightmode Change After Geofence Breach
Hi community,
I’m looking for clarification regarding setting the FENCE_OPTIONS bit 0. In the documentation, it says “Disable mode change following fence action until fence breach is cleared”. Does that include RC/pilot flight mode changes?
Vehicle is an experimental tailsitter. I’m concerned it would breach the fence in FW mode, stop responding to pilot intervention and fail to RTL/QRTL. On the other hand, I’m concerned it would get stuck changing between flight modes if I unset the bit, which happened previously with a certain other autopilot :slight_smile: I switched to Ardupilot after that incident!
Thank you!
Yes. This is off by default on copter for the reasons you state. The reason it exists is for regulatory compliance.
Thank you for the help and all your Ardupilot contributions!
As feedback to developers, it would be nice to add a third option where automatic flight mode changes are disabled and manual flight mode changes are enabled.
