I’m working with missions who are created in advanced. This helps me to be as efficient as possible on the field. But sometimes I need to adjust the flight altitude and the altitude mode (Terrain, Relative). It’s very time-consuming to modify every column individually. To improve this situation maybe a “search and replace” tool could be the way to go.
What you guys think about it? Maybe someone else have even better ideas…?
I use to use trajectories with two different heights waypoints. To modify them easily I edit the waypoints file directly, with a column selection editor (Geany, Textpad…).
I have seen that some values will be negative if I reduce the altitude… But I assume that those negative values will be ignore by the flight controller?
And for modifying the altitude mode all at once. Will be there a option in the future? It would be very nice if we can modify the mission in a easy way directly in the mission planner flight tab.
