Unfortunately for me, it did not work. When I clicked on the Param gen, the green box turned a little darker, indicating that I did indeed click on it. However I did not see that it was downloading anything. After about 10 seconds, the green box returned to the same shade as the other boxes. Having zero experience with this, I do not know if this means it downloaded or did not. Either way, the missing text/drop down boxes do not work.
I have found some other screens where the drop down boxes do not show any text either. On the same screens though, I have found some text boxes (that already have text in them) that can be clicked on and the drop down box shows multiple options in text.
Downloaded Mission Planner and it worked!! I can see text in the boxes and can now program the flight modes!
I was trying to use Mission Planner on my desktop that is running Windows XP SP3. I would still like to use MP on the Win XP computer though. Is mission planner not compatible with Win XP?
I finally got to fly my X8 and successfully changed flight modes in the air. Yes!!
Thanks MarkM. I had the same problem. Your tip worked in my case. Got in Full Parameter list Units, Options and Desc texts also what I was missing before. Awesome! I am running MP 1.3.30, ArduRover 2.50 on Win7 32 bit
I have the same problem. No text in the dropdown lists for flight modes. I have tried the “Ctrl+f” trick but then mission planner hangs and i have to kill it in Task Manager.
Have also tried to download the latest MP and reinstall, but still no luck.
I have not used the MP the last half year and before starting to use it now, I upgraded. Have never had this problem in earlier versions.
Any more hints, anyone?
