So I have 2 APM 2.6s One in a hex and one in a plane. In the basic tuning screen in mission planner for coppter there is an option for an extra channel for flight modes. So I can use my 3 position switch for 3 modes then my gear switch for one-2 more. I am now working on my plane and there is no option in mission planner to do the same. Is this normal? I want to set RTL on my gear switch and have stabilize, loiter and auto on my 3 position switch.
Tconners,
That is normal. What many will do is mix in a two-position switch to their primary three-position switch, effectively giving that three-position switch 6 positions. This likely doesn’t exactly meet your need, but is an option.
Mixing is radio dependant, but you can start here if you like for some inspiration and then take it from there:
copter.ardupilot.com/wiki/common-six-modes/
Hope this helps…
