I am trying to use the Intel Realsense t265 Tracking camera as the GPS for my rover. To set up the parameters and code, I used the following link: https://ardupilot.org/rover/docs/common-vio-tracking-camera.html
However, when I run the code t265_to_mavlink.py, my rover does not appear in the simulator, and when I try to switch to guided mode, it says “flight mode change failed.”
The other errors that it gives are “Bad compass health,” and an EKF failsafe. We tried changing to the camera’s compass and turning off the compass but still got a failsafe (the failsafe was not specific).
In the simulator we can see the values changing for " VISION_POSITION_ESTIMATE" as they should.
Has anybody gotten the realsense camera to work as the gps in guided mode? or have any suggestions?
Let me know if you need more information.
Thanks,
Julia
