I am building an autonomous boat using Ardurover. Whenever I attempt to switch to Auto mode I get this message and the flight mode fails to change. What could be wrong? I created a mission and uploaded it to my boat. The flight controller arms and doesn’t report any problems.
Nigel,
It’s most likely that it doesn’t have a good GPS lock, or more accurately, the EKF doesn’t have a good position estimate. It’s also possible for the EKF to become unhappy if it has a bad compass heading.
The other somewhat unlikely possibility is a badly formatted mission. It was uploading using the Mission Planner?
If you have a dataflash log we can take a look but it’s almost guaranteed to be a bad GPS position.
Hi Nigel,
Did you solve the problem?
Why don’t you follow these process:
- mode GUIDED,
- arm throttle,
- mode AUTO
Sincerely,
Dongsin
Did you end up finding a solution if so please share as I’m having this exact issue
I’m getting the same error “Flight Note Change Failed”. I have rtk Fixed so I wouldn’t know what to diagnose or debug… @tridge would you offer a suggestion?? log7.bin (355.9 KB)
Have not learnt how to read logs yet but have you made a mission task as it needs to be ready and click write wp.
Can you see the flight modes change when flipping the 3 stage switch on your RC.have you made all the calibrations.
Nevermind. I had AHRS_EKF_TYPE wrong (had set it to 3 when experimenting earlier today; set it back to 2 and all is fine).
I encountered the same problem, please solve the problem of the owner, can you tell me how to solve it?
Hello and thank you for sharing your experience
I did it but no luck
do you have any other solution to recommend us?
No success my friend
do you have any other idea
mybe you can keep away from metal,and just calibration ,
Hi everyone,
Can some experts help us please?
manual works perfect. Gps locked and EFK normal.
When Disarmed : switch flight mode from Manual to Auto or Manual to RTL works
When armed : switch flight mode from Manual to Auto or Manual to RTL doesn’t work : I have a message flight mode change failed.
Also: when disarmed with the flight mode is Auto or RTL, then armed. Auto or RTL is working.
Can anyone please help?
Thanks a lot for your support.
Yohan
I found the issue: I have calibrated the compass from the GPS and the Pixhawk separately so it creates variance problem. Also, I tested the gps on my terrasse but it seems that the gps is very weak when the boat is closed to a building.
Solution: calibrate all compass at the same time + use only 1 compass to avoid variance error + use the boat far from buildings
