Hi folks!
I was wondering if someone could explain to me what the pink track is in the “flight data” map. Attached is a pic of my flight data map which looks like the quad is seemingly drifting around, although it is stationary on my desk. Is this “drifting” something I should be concerned about? My GPS HDOP shows 1.98.
Not to worry… Because your MR is stationary the GPS has nothing to “lock on to” so spurious information
is generated hence the wanderings, pick up your craft and take it for a walk … mediately the GPS will lock
to the movement …by the way movement need only be quite slight …the pink track will follow behind you!!
