I generally run DSHOT600. MOT_PWM_TYPE 6
Thanks for suggestions.
Without any issue itās runing and is that same esc your using T.motor F45A BLHeli esc.
No but I have used a lot of blheli_32 escās single and 4 in 1 and not had an issue.
Which flight controller is a V5 nano ?
I have both cuav v5+ and v5 nano as well.if use BLHeli esc we donāt want to set MOT_PWM_MIN and MOT_PWM_MAX ?
Calibration donāt need and any others tips to improve performance.because this is 1st time iam going to use BLHeli esc instead of Normal Pwm esc .
Dshot stability was a bit of a moving target on previous revisions of Ardupilot with individual combinations of Flight Controllers (F4/F7/H7) and ESCās giving unreliable results. But this seems to be mostly solved in the the latest beta and master. I also typically use Dshot600. 1200 on one tiny quad.
No you donāt set pwm low or high. Just connect them up set params and your good to go. Making sure you have followed the docs. There are a couple of things you have to be careful of if itās has an iomcu
You will find if you select a Dshot protocol these will automatically change to a default value. Donāt change it.
Yes I saw one of ardupilot threads andypler said that still more realiable performance will come in 4.1.0.
Thank you so much for your time.
Thank you soo much ā¦I will keep post when my 1st testing done .
I like that
Itās any recommendations that BLHeli esc only use for racing quad and not for normal Quadcopter?
Made me smile Dave
I use it on most things I fly, my dart plane has dshot on it too.
Thank you ukmook .
As @ukmook says I also use it on all craft if possible. On multirotors there is a big advantage having ESC telemetry with RPM for the Notch Filter configuration. Or bi-directional Dshot but thatās still Dshot!
Unfortunately my esc did not have esc telemetry itās T.motor F45A BLHeli esc.
You could try Bi-Directional Dshot if there is firmware for your Flight Controller. This will provide Motor RPM on the ESC signal wires. Itās actually a better source of Motor RPM than standard telemetry.
Once you have it all setup and working, you may be able to use bi-directional dshot the esc can do it iām just not up on those flight controllers. which will send motor rpm on the same signal wire. Which in turn helps with notch filters etc
What dave said lol
There is a BDshot target for CUAV X7 in the Beta repository. Iām using it on Matek and Kakute boards.
