burned up a motor and replaced them w/ sunnysky, done all calibrations repeatedly and cannot get it to quit spinning! is there something in mission planner that i’m missing??
thanks
Sounds like its spinning the wrong way
Have tried calibrating the ESC’s so the motors are synced. Also there is a number of parameters that can be set to quiet the motors. THR_MIN =
Mike
Be sure the motors are spinning in the correct direction. Sounds like you have it backward or setup your quad as an H instead of X.
Motor 1 and 2 should spin CCW
Motor 3 and 4 should spin CW
You guys are awesome, cw and ccw reversed!
