Flashing CubeOrange plus
I’m trying to flash CubeOrange plus with ST link, but getting the errors “Error: Failed to erase memory” and others as shown in the screenshots attached.
Can someone help me with resolving this?
Use Mission Planner or QGC to flash. The Cube should come with a bootloader capable of receiving firmware from either. A lower level programmer requires DFU mode, which cannot be accessed without unnecessary disassembly.
Thanks @Yuri_Rage for the reply.
We are using custom signed arducopter bootloader - firmware combination. So we need to flash the bootloader as well which is where the issue is right now. Is there any flags to be set to enable flashing?
I also want to sign FW and upload it.
Currently, when I am following Creating Tamperproof Firmware — Dev documentation for cubeorangeplus I am stuck with a memory linking error.
I just show when I am flashing default FW it only leaves around 8kb of free memory. so when I am attempting to sign fw it throws memory regarding error. So I think it must be due to lake of memory.
Can you help me to figure it out.
