In the Setup tab under Servo Output for configuring a new plane the motor and flap sliders indicate they are not outputing the signal from the radio. The radio configuration went fine, the inputs were recorded. When the plane is armed, the Servo Output problem is verified, neither the motor nor flaps respond to radio inputs, while the other commands work fine.
The ESC cannot be calibrated, I assume because there is no output, although when I hit the calibrate button in the ESC Config window the “set param error. Please ensure your version is AC3.3+” error shows up.
Thanks for any help.
