Fixing Bad State/Bricked Cube Orange Plus with ArduCopter OpenDroneID Firmware
I was trying to add OpenDroneID firmware to a Cube Orange Plus following this tutorial: How to add RemoteID to ArduPilot Systems (youtube.com)
This tutorial is for the Cube Orange, but there was no specific firmware and bootloader for the Cube Orange Plus. I followed the tutorial and instead uploaded the OpenDroneID firmware and bootloader for the Cube Orange. After uploading the new firmware, the IMU0 errored, but the Cube Orange Plus continued to respond. Then, I uploaded the new bootloader according to the instructions and rebooted the Cube Orange Plus.
The Cube Orange Plus was no longer detected by my computer. The Cube LED did not do its normal boot up cycle but instead stayed orange without flashing as it normally would. I also plugged in the speaker which just continually blared and did not play the normal boot up sound.
IMG_0878
I opened Mission Planner and tried to upload a bootloader but got this error:
Scan2
After reading online material, I discovered two possible solutions to reset and upload a new bootloader: 1. Break open the Cube Orange Plus and manually short the boot pin to reset the internal STM32 or 2. Use a Black Magic Probe (Black Magic Probe with JTAG Cable and Serial Cable [V2.3] : ID 3839 : $74.95 : Adafruit Industries, Unique & fun DIY electronics and kits) to reset the Cube through the DFU Debug port on the ADS-B Carrier Board.
I opted to try the second option and got the Black Magic Probe. I connected the board via the JTAG interface and adapter shown below:
IMG_0877
The BlackMagic Probe is (COM3 and COM4, COM3 is for the connection to the Cube). Then I tried powering the board both through a micro-USB and through the BlackMagic Probe and scanning for either a JTAG and SWD scan to find the STM32, but despite having a detected target voltage of 3.3V, the board scan failed and never found the Cube Orange Plus’s STM32 chip.
Scan1
Any ideas on how to fix this Cube Orange Plus? Is it bricked? If so, is there a way to upload a new bootloader without breaking open the Cube Orange Plus itself?
Realized the photos didn’t upload properly
Seems you’ve overwritten the H757 bootloader with one intended for an H743, which is darn close to bricked, but I think recoverable.
I don’t have specific experience with JTAG connection to a Cube autopilot or cracking the case on one, but you’ll surely need to successfully enter DFU mode. Before you start breaking seals, double and triple check the wiring on the JTAG port. Seems that method SHOULD be feasible…
Once it’s in DFU mode, STM32CubeProgrammer or dfu-util will easily flash the chip. That much I do have experience with, and it’s painless if you can get it to the point where DFU mode is possible.
Hi – were you ever able to resolve this? I am struggling with the same issue with a Cube Orange Plus Mini. For some reason, when I flash the device via the ./waf copter --upload method after configuring for --board=CubeOrangePlus, it also reports that there is an H743 bootloader rather than the H757 mentioned. Same behavior where on connecting, the LED flashes for a couple seconds but then stays solid.
I thought that it might be that there is a separate board configuration flag for the mini versus the normal Orange Cube Plus carrier board (like there is a Pixhawk4 and a PH4-mini as separate options for the --board option), but I can’t identify one.
