I’m using this install on BBBlu
I’m using this image.
I got arducopter working with qgroundstation.
I wanted to run up some perl scripts that I have used on the raspberrypi.
I have had a fun day trying to work out why I cant use cpan to load perl modules.
It comes up with
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = “pl_PL.UTF-8”
are supported and installed on your system.
After much searching I found a fix.
It looks like the locale aren’t installed or broken.
Here’s the fix:
sudo apt-get purge locales
sudo apt-get install locales
sudo dpkg-reconfigure locales
During the last, it will ask you to pick your locale.
Just pick the one that’s a match for your country.
After that I loaded latest cpan.
But had to install build-essential
sudo apt-get install build-essential
sudo cpan
install CPAN
reload CPAN
quit
After this everything worked fine.
I spent a number of hours debugging this problem so I thought would share to save others the pain.
