hello there,
this is the first time using Mission planner and arduplane but i do have experience with betaflight so im not a complete rookie I have a matek f756 wing that i am setting up for the first time, i am using the latest mp and the latest arduplane downloaded on 1.8.21(mission planner 1.3.74 build 1.3.7563.27684 and arduplane v4.0.8beta1(5ffd40f9). so far flashing and setting up the fc has been fairly uneventful, untill i plugged the power in and my esc smoked, a mosfet burned up, the esc was a spedix gs 35amp which is a blheli 32 esc. which im trying to set up for dshot protocol and also telemetry to serial 5. i want to provide a dump so you guys can look it over and see if it was any settings that i changed that smoked my esc. can someone explain what and where to get the parameters for you guys to look at.
i want to use one motor on this plane, which is on servo1. with timer groups i will only beable to use servo one and two using dshot protocol. is there anything i need to do to servo2 to turn it off? or is just not hooking anything up to the servo port good enough?
thank you for you time,
wayne
