I’m converting an Parallax ELEV8-V3 quadcopter to a Pixhawk 2.1 flight controller. This is the first flight analysis.
I don’t understand 2 lines:
Test: Parameters = FAIL - ‘THR_MIN’ not found
Test: PM = WARN - 3 slow loop lines found, max 8.45% on line 61929
---- Here is the entire result —
Log File C:\Users\kenmc\AppData\Local\Temp\tmpC2B8.tmp.log
Size (kb) 6214.4814453125
No of lines 71853
Duration 0:04:12
Vehicletype ArduCopter
Firmware Version V3.5.4
Firmware Hash 284349c3
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Brownout = GOOD -
Test: Compass = GOOD - mag_field interference within limits (5.12%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = GOOD -
Test: IMU Mismatch = GOOD - (Mismatch: 0.27, WARN: 0.75, FAIL: 1.50)
Test: Motor Balance = GOOD - Motor channel averages = [1421, 1417, 1410, 1411]
Average motor output = 1414
Difference between min and max motor averages = 11
Test: NaNs = GOOD -
Test: OpticalFlow = FAIL - FAIL: no optical flow data
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = UNKNOWN - No CURR log data
Thanks for any help.
KenMc
