rotems
(rotems)
February 23, 2021, 11:51pm
1
I’ve tried to upgrade firmware from 4.03 to 4.07 (Drotek pixhawk 3 pro) but I’m getting the following message:
Error: firmware image is too large for this board
I uploaded a small size firmware of the Antennatracker but now no other firmware can be uploaded.
Please help.
Thank you
Rotem
tridge
(tridge)
February 24, 2021, 4:38am
2
this could be a bug in our bootlooder. I could give you a test firmware with an updated bootloader that may fix the issue. Then you could update the bootloader from that image. Would you like to try that?
rotems
(rotems)
February 24, 2021, 5:53am
3
Hello tridge,
Yes please, I’ll try.
Thank you very much
Rotem
tridge
(tridge)
February 24, 2021, 8:04pm
4
Download and install this copter firmware:
http://uav.tridgell.net/DrotekP3Pro/copter-DrotekP3Pro-small.apj
that is a feature-reduced version of copter that fits in 1M of flash.
then follow this guide to update the bootloader:
https://ardupilot.org/copter/docs/common-bootloader-update.html
after you have done that you should be able to load normal firmware for this board.
Please let me know how it goes
rotems
(rotems)
February 25, 2021, 7:49am
5
Hello tridge,
I’ve installed the feature reduced firmware but it refused to update the bootloader with mission planner and Qground control.
Thank you
Rotem
See attached images.
tridge
(tridge)
February 25, 2021, 10:14pm
6
thanks for testing, I think I’ve found the cause, can you try again with this firmware?
http://uav.tridgell.net/DrotekP3Pro/copter-DrotekP3Pro-small-test2.apj
rotems
(rotems)
February 26, 2021, 1:25pm
7
Hello tridge,
It worked!
Thank you very much for your support.
Rotem
tridge
(tridge)
February 28, 2021, 6:23am
8
great! thanks for testing
Markskyyy
(Mark Yanushevskyy)
February 8, 2022, 2:53pm
9
Hello everybody, I have the seme issue with Pixhack v3. Can`t update firmware. Can somebody help me?
