Trying to Sort a FM conflict.
I’ve programmed MP Channel 7 for RTL on separate Radio Switch (not under CH 5 and the 6 FM’s)
However: When RTL Switch is triggered FM4 is activated. No matter what FM is set in FM4.
I disabled all FS’s thinking there maybe a link there, but the outcome is the same.
The only way I’ve been successful in creating Channel 7 /RTL in all FM’s is to program CH4 as RTL also.
As anyone else seen this connection before?
Thanks for any insights you may have,
SC
Channel 5
FM1 STAB
FM2 ALTHLD
FM3 Loiter
FM4 RTL
FM5 AUTO
FM6 CIRCLE
Channel 6 (none)
Channel 7 RTL
Channel 8 Super Simple
PH 2.4.5 clone
AC 3.2
TaranisTX x8rRX
yes I have experienced the same behavior.
But in fact this does not matter.
Ch7/8 override Ch5 for RTL. When you switch back, Ch5 will be in the original flight mode again.
You are correct when switching back all is as programmed. Not sure I completely follow though.
If I trigger CH7/8/RTL, and FM4 is programmed for AUTO (or whatever MODE is programmed at FM4 ) then AUTO shows up on MP as the Current MODE. This effects all FM’s 1 through 6.
Since I discovered this I’ve only flown with CH7/8 and CH4 both as RTL. It way it performs fine relative to the other FM’s.
Perhaps I can program a different FM on CH4 and actually flight test to “see what develops.” lol
[quote=“mtbsteve”]yes I have experienced the same behavior.
Ch7/8 override Ch5 for RTL. When you switch back, Ch5 will be in the original flight mode again.[/quote]
My work around for RTL to overwrite all modes requires programming RTL on Channel 7/8 plus programming RTL on FlightMode 4.
AUTOTUNE (Not Possible): My previous work around is not possible because AutoTune is only an option on Channel7/8… And not as a Flight Mode.
It would be great to determine if this is only my issue or a possible 3.2 issue.
Thanks,SC
[quote=“FullScalePilot2”]Trying to Sort a FM conflict.
SC
Channel 5
FM1 STAB
FM2 ALTHLD
FM3 Loiter
FM4 RTL
FM5 AUTO
FM6 CIRCLE
Channel 6 (none)
Channel 7 RTL
PH 2.4.5 clone
AC 3.2
TaranisTX x8rRX[/quote]
After much searching and testing I found no explanation for the apparent connection between Flight Mode 4 and Channel 7. But I did find success with Auto Tune and as I mentioned, the work around for RTL.
AUTO TUNE: Perhaps it’s a coincidence, but I have noticed Randy Mackay, et al choosing Flight Mode 4 set to Alt Hold when preparing to Auto Tune. So I did the same and had no problems completing Auto Tune.
Thanks for your comment. Perhaps there is something lost in translation.
I was aware Alt Hold is required to trigger Auto Tune.
However, I found no instruction that Flight Mode 4 is the only MODE to program Alt Hold.
Best, SC
[quote=“around”]Not a coincidence, the AutoTune procedure requires you to put the vehicle in AltHold prior to starting AutoTune
