Dear all,
I am trying to setup a FETtec 4in1 ESC 45A via OneWire on a Cube Orange, GPS1/serial3. I did not use the bdshot option when uploading the firmware (v4.5.3).
@TeeZee : I bought the ESC directly from your shop a week ago, didn’t have the possibility to check the firmware on the ESC yet (i was assuming it was the latest one).
You might have to check with the esc firmware, Flash it with the latest and it should work just fine.
Kindly note
tlm 1& 2 Are serial 1&2
gps 2 is Serial 4
Use fettec web configurator : FETtec Configurator
connect FTDI adapter TX & RX with an diode and resistor (use 3.3v for vcc) and TLM and GND to the esc as per below pic
I hope the esc is disconnected from it signal connection with the FC and only FTDI is connected.
also pullup has to be provided previous schematic, use a fast diode.
If possible remove the parallel connection with esc’s for flashing purpose
Yes FC signals are disconnected. I tried the diodes SM4006PL and ES1DL, both give the same error. I think I’ll give up. If I could be sure that this is an ESC firmware issue, I might try again. But the firmware code isn’t public and therefore I can’t compare the changes. Release notes do not mention any issues with onewire.
it is because of FW, I have rigs running Fettec Onewire here.
just make sure about the ftdi circuit is correct and the job should be done. as simple as that.
I tried 1k and 4k7 and 1M, nothing works. Circuit is as in your image. Telemetry inside the Fettec GUI works. I am giving up on this, thanks for your efforts!
