ArduCopter 3.1 - If I want to use Tx channel 7 to enable/disable Fence (set on ArduCopter PIDs screen), should the Software/GeoFence Enable button be set to “disable” or does it matter?
Thanks
[quote=“rslegge”]ArduCopter 3.1 - If I want to use Tx channel 7 to enable/disable Fence (set on ArduCopter PIDs screen), should the Software/GeoFence Enable button be set to “disable” or does it matter?
Thanks[/quote]
I havent tested this case, but the settings I have tried that use an input usually update on the mission planner screen after using the refreshing parameters ( i think thats what its called) button.
so try switching it on and off using the input, refresh between changes and see if the screen updates to suit.
Stu
Thanks Stu,
I could not see the value changing when I was using TX channel 7. The tip I needed was to refresh the parms to show the value changed. So I left fence unchecked in ArduCopter PIDs screen and channel 7 let me turn it on and off. I test flew today and everything worked as expected. You can really see the quad hitting the fence and switching into RTL.
Brill, glad it worked. I haven’t played with get fence yet.
sent from my phone so apologies for any typos
